Problems with just one contact
Not applicable
Hello there,
I can't send a SMS to just one of my contacts getting an error from sonyericsson.conversations. Other contacts are working fine. It's a X10 Mini and resetting the Phone doesn''t work either. Didn't change something before...
1 ACCEPTED SOLUTION
Martha-
Contributor
Have you tried deleting the contact and re-entering it?
2 REPLIES 2
Martha-
Contributor
Not applicable
Right, it worked! I'd tried to copy it without a result, but completely new typing not. Thanks a lot Slightly_smiling_Face
