Why is my Xperia SP so slow?
gino76ph
Hi.
Bought a brand new pay-as-you-go Xperia SP on EE. But a few days ago had an Alcatel One Touch Idol S with specs lower than the SP.
But i noticed that the Idol S is relatively faster than the Xperia SP in terms of initial startup, downloading/installing apps, opening/closing and flicking thru homescreens.
I wonder why is that?
Any advice please?
42 REPLIES 42
profile.country.RO.title
_alexdon_
I think you need to unistall updates first,then the disable button should appear.
alexdon
gino76ph
I have done that. I have basically reset the phone and installed updates. But where or how do i disabel them bloatwares?
_alexdon_
Go to settings-apps-all,select the app you want to disable,uninstall updates(it is a button),after that you should get the button disable.
alexdon
gino76ph
It only says "Force Stop" or "Uninstall". No Disable option.
And on the 3 small dots on the upper corner there is no such thing as say "Stop All" or something like "Stop Few".
_alexdon_
Then I really don't know,you can try to force close those apps.However,they will activate every time the phone is restarted.
alexdon
kiranPatel710
My phone is getting slow y????
_alexdon_
Because you are either using a lof of apps without closing the previous,or you do not restart your phone regularly,so the RAM is not refreshed.
alexdon
Knighty20
mine is too slow so i decided to reinstall the update..i hope that can fix some problems...
_alexdon_
It will.keep us updated.
alexdon
Knighty20
i just reinstall the update unfortunately its still slow, the walkman on locked screen still not worked, but the volume indicator and screenshot are fixed...that's all that i noticed not much.. Slightly_frowning_Face
