Recently Unlocked bootloader officially from sony mobile website
later on rooted it from xda
installed custom recovery mode through FASTBOOT MODE
after installing it led me to recovery mode
i backed up my data
then i selected REBOOT SYSTEM NOW
but its again rebooting to recovery mode
not going beyond that !
how do i get over it ?
i have not used flashtool
version :
ICS
2.45
Download this https://docs.google.com/open?id=0B-yM_qnM8ZPRNWU5R0tnblhUYkk and stick it in your Fastboot folder on C: Drive then open a command prompt and type fastboot flash boot kernel.sin then hit enter and connect your phone in fastboot mode
Takes seconds to complete - Once done your phone should reboot if not then you may have to use Flashtools or the new Sony repair program
it showed as finished ! but nothing further !
Have you tried to start your phone - You may have to hold the vol up and power as mentioned before
Awesome ! thank you
No bother - But if you could mark any of answers as correct or helpful if you feel I have been
Edit - I see you have
the phone is still rooted
How do i enter into recovery mode without being stuck agin and install custom roms ?
Recovery mode is a separate file which you need to flash using fastboot the proper file to use is the nozomi file found on my drive here https://docs.google.com/open?id=0B-yM_qnM8ZPRU2VWazlla19tWE0
To use as you just did with the kernal.sin you need to copy it to your fastboot folder and type in
fastboot flash boot recovery-nozomi.img then your phone will boot into recovery then to fix that re-flash the kernal.sin
