Recently Unlocked bootloader officially from sony mobile website
later on rooted it from xda
installed custom recovery mode through FASTBOOT MODE
after installing it led me to recovery mode
i backed up my data
then i selected REBOOT SYSTEM NOW
but its again rebooting to recovery mode
not going beyond that !
how do i get over it ?
If you do want to flash a custom rom then place the img in your fastboot folder open a command prompt and type in fastboot flash system FILENAME FILENAME been the name of the img
remember to add .img at the end in the cmd window or it won't work -
To revert back to a Stock Rom then you will need Flashtools and a .FTF file
you can find these on XDA here
http://forum.xda-developers.com/showthread.php?t=1599303
how to relock bootloader ?
one thread its more than enough
To relock the bootloader you need Flashtools installed when you have done that and have installed the drivers come back
To check the drivers are installed Turn your phone off. Press and hold the volume down key while plugging the USB cable into your Xperia S.
Or because your bootloader is unlocked then if you are wanting to go back to stock then use Sony's official flashtools http://developer.sonymobile.com/services/flash-tool/
had installed AOKP
found it unstable
(camera not wrking)
before relocking
i would like to know
is latest cm10 by FXP stable enough on Xperia S ?
Don't know never use that stuff
have downloaded installed flastools !
Download and place in Flashtools Firmware folder https://docs.google.com/open?id=0B-yM_qnM8ZPRTDhsS1ZHbXJ2YWs
Open the Flashtool application on your PC. Click on the lightning bolt symbol.
Select Flashmode and click OK
Select the correct firmware in the left column in this case select Relock-Bootloader
If you uncheck the “wipe userdata” box in Flashtool before flashing, you will not lose any data. Click ‘OK’.
Turn your phone off. When prompted press and hold the volume down key while plugging the USB cable into your Xperia S.Ignore the instructions from the pop-up window as these are for a different Xperia phone.
The flashing process should now start
Once you see the “Flashing finished” message unplug your phone and boot your phone up
I flashed the relock bootloader ftf file through flashtool ! it showed as finish,,unplugged USB ,powered on via power button ! it just vibrates once and does nothing ! phone is not booting at all !
