Hello guys, I have the Xperia tipo dual. and I have a problem, my proximity sensor is not working or maybe it doesn't exist, some sites says it has but my phone on the *#*#7378423#*#* (This menu or something similar) Proximity sensor says "Not Detected" , Does it have or not? Because if it doesn't I must get a new phone :smileysad:, always in my calls I press buttons, mute the call, and everything, sometimes hang it up, because the screen doesn't go off.
Please help me up 😕
After the new update 11.0.A.6.5 it started working great! Problem solved.
that's the Service Menu, what does it happen when you test your proximity sensor? post a screenshot
screenshot = press and hold volume down & power for 2 seconds
Don't forget to mark the Correct Answers & Helpful Answers
unrelated topic, if you have some time please check this thread
I've already told you but if you want a screenshot ok
It says not detected.
Why does this happen?
repair it with SUS if that doesn't do it, then take it to a sony repair center
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
http://software.sonymobile.com/install_packs/Update_Service_Setup-2.12.12.41.exe
I've done it and I saw that I made a mistake, when it still says "Not Detected" but when I put my hand over the sensor it says "Detected" XD.
I thought that it says the proximity sensor is not detected on the system.
So now I know the sensor is working whenever I put my hand, but on calls the screen never goes black
What's the problem? 😕
lol, then it does work, when you press those keys while making calls do you keep the phone next/touching your ear or in a pocket?
I've tried covering the sensor with my hands my ear the table my legs, everything the screen doesn't go off it's still on
but on the service test it says detected when I put my hand 😕
the screen only go off during a call
Yes I know! The problem is that the screen doesn't go off during a call and I press buttons while in call with my ear
that's a bit odd. try a different Dialer app from the market. you should take your phone to a Sony repair center.
