YouTube app problem
kirin24
YouTube app problem
Hello, recently i've updated to the last update of the YouTube app. Now when I try to launch the app it takes at least 6-7 seconds to open and at times it doesn't launch and nothing happens when I touch the YouTube icon in my app tray. It is really anoying and I can't use this app well. Does this have to do with my phone?
It happens only for the YouTube app
I am using android gngerbread 2.3.7
1 ACCEPTED SOLUTION
profile.country.RO.title
_alexdon_
Try to uninstall updates for youtube app.
alexdon
9 REPLIES 9
_alexdon_
Settings-apps-all-youtube,force stop and clear data.Restart your phone and try again.
alexdon
kirin24
I've tried to do that and it started working back well but after using the app for quite a time the problem starts again.
Should I repeat these steps everytime that happen ?
_alexdon_
Well,how much has passed since you did that?I remember that someone on the forum said that youtube has given up support for 2.3.7 GB,so you could start using youtube on your browser.
alexdon
kirin24
About a 2-3 days
_alexdon_
Try to clear data again and see for how long it works.If still having issues,come back here.
alexdon
kirin24
The problem still happens at time but it doesn't bother me at all as I use youtube on my browser
_alexdon_
alexdon
VanNernieBalsom
I already did it but it didn't work what should I will do?
_alexdon_
@VanNernieBalsomo what phone do you have? what is the actual problem?
alexdon
