Since I install Win 7 on Sony Vaio VGN-FS395 I don´t get sound and can´t use the fn-key kombination, where can I get the drivers? Please help me thanks very much
Best regards Antti
Hi Hulkko and welcome.
Sony do not support Windows 7 on your model but they do support Vista 32-bit and the drivers and utilities should work with Windows 7. There is no Windows 7 64-bit support.
Try downloading and installing ALL the drivers and utilities listed under the "Vista" Tab here: -
http://www.sony.co.uk/support/en/product/VGN-FS395VP/updates
You will see the Realtec Audio Driver at the bottom.
To get the Fn-Keys to work, install the following utilities IN THIS ORDER: -
1. Sony Utils DLL
2. Sony Shared Library
3. Setting Utility Series
4. Vaio Event Service
After you have installed all the Vista downloads, there are a few additional downloads under the Windows 7 Tab.
1. Sony Utils DLL
