Dear Manolo
Many thanks indeed for your prompt and very helpful advice. In the end it was not needed because the problem cured itself. Two days after reporting the fault, the network status suddenly changed from 'Wireless device on TV: Not accessible' to 'Wireless device on TV: Found'. No parameters or settings had been changed, so the cause will forever remain a mystery. Let's hope it doesn't happen again.
Best wishes from Ray.
