zi4kis
Neues Mitglied
internet verbindung
hallo
ich muss leider auf englische schreiben, mein deutsch ist nicht ganz gut.
i have sony tv Model KD-55X8505C and i cant connect it anymore to internet. my internet provider is UPC-Cablecom. i had before Ubee router (not wlan) and i had my own netgear wlan installed. i was able to connect my tv to netgear through wlan and it was good. since 2 days i got a wlan router from UPC and it is called connect box. so i am trying to connet my tv wirelessly but it is not working. it says connected but not internet access. so i decided to connect it wirely. so i press Home button, settings,  network, network setup, easy, and then wired lan. i go through the instructions on screen:
are you using a modem? yes
does your modem have router functionality ? yes
then, could not connect to internet, and there is the option ASSIGN A STATIC IP ADDRESS
and i have 3 laptops, 2 cellphones and ps4 connected through wlan to Connect Box normally.
so the question is, what should i do to get internet access again??
thanks
Tags (1)
