- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
November 2016
November 2016
I just bought a BDP-S3700 and had exactly the same problem. I could connect to my wifi but failed to connect to the internet. I called my ISP butthey said as everything else connected to my wifi, it must be an issue with the DVD player.
I found the answer in the Support community, the link is
You need to enter some settings manually to connect. The important one is tis
- IP address or IPv4 address - which needs to be set higher than it is on your own computer.
I have an iMac and it is in system preferences, network.
I'm no ID guru but I did it. I nearley tore all my hair out and was just about to give up and return the DVD player to the store.
Good luck.
