Who Me Too'd this topic
dj777149
STR-DN1080 and Songpal / Music Centre
Hi everyone,
I aplogise if this has been brought up before. I've tried searching this forum and the internet beyond, but so far no joy.
I recently bought a STR-DN1080 and overall I'm very happy with it. However I am having trouble connecting to it with the Music Centre app. It will connect fine using Bluetooth, and I used the app to set up the 1080's wifi connection to our network. This also worked ok.
Unfortunately now the app cannot find the 1080 on the wifi anymore, only via Bluetooth. I've also tried a generic "Audio Remote" app with the same problem, even though it worked ok before. Other apps work fine over wifi, for example I can "cast" using Tuned In or Chromecast with no problems. I suspect the problems may have started after the 1080 decided to update its software.
Has anyone else experienced this, or can offer any advice?
Thanks
