- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello Sony Tablet users!
I experienced this bug/error sometimes, I have no idea why.
After (not) closing the internal Music App with the 'Home' Button,
the error [Database update failed] appears on the "taskbar" next to the clock.
and when I start the Music App again - all the Music-Files appear anymore.
After installing and uninstalling other apps and even resetting the entire tablet I only "solved" this problem by killig the app "Media players" by 'force stop'
Applications->
Manage Applications->
All->
Then scroll down and select "Media players"
click to "Force stop"
and open the Music app again - and there they are my Music Files again :smileygrin:
I don't know what the cause of this error is
As the app dosn't really crash, Android doesn't make any error report which I can send to them to look into it and solve it with the next Honeycomb update.
I hope this instruction help you temporarily...
1. Does anyone experienced the same bug?
2. Does anyone know another way to permanently solve this problem?
/ without advising me to install any other App like Player Pro which I have on my Sony Xperia Arc and works perfectly - as I really like the Visualisation thingi and the throw thingi on the preinstalled Sony Music App
Thanks for your feedback!
