Who Me Too'd this solution
dutchice
Hi @suej70,
Welcome to the Sony Online Community! It is very unfortunate but the issue you are experiencing is a common exhibiting fault across the entire X8305c line. There is nothing you could have done differently in preventing the fault. The mainboard will require a replacement.
I suggest you contact Sony Support and open a case for the TV. They will be able to verify if your TV is still under warranty and can book a repair for you. Else if it is not, they still can suggest what would be the course of action.
Hope you find my reply useful.
Cheers,
Dutchice
