Xperia SP WIFI range ISSUE
ak_newlife
Hi, i have just bought Sp 2 days back
I am facing wifi range problem the device does not catch the range where my other phone catches the range at good wifi signal strength.
the distance is like 3 to 5 meters less then my black berry
Is there any settings that i need to see for the wifi range.
205 REPLIES 205
ZdendaF
I have the same wifi range issue on my new SP.
I have old Xperia Neo V and it has a full signal in the room where router is placed. But Xperia SP doesn't have a full signal in the same place like Neo V. Sometimes disconnect my SP from the WIFI.
I try to change the wifi router, but the situation is the same.
Is there any solution to solve this?
Thanks
KenL
You're not the only one , it even happen at outside free wifi spot . It always disconnects
Jasonwsc
The range is weaker compared to other phones, but I still get enough signal and speed for browsing and streaming videos. Same goes for mobile networks. Hopefully this can be solved with a software (baseband) update.
vikigsv
hi,
i have the same problem. All my other devices xperia mini pro, lumia etc have good signal and working fine but SP's signal is not stable and keeps on disconnecting. Any solutions please update.
ak_newlife
Guys Few Observation
The Wifi Range and Network is being affected cause of the metal frame hope iam wrong
i tried covering the all the cornor with hand and i did observer a network drop in wifi signal try doing this and let us know
try covering the lower half of the phone
Cromulent
This problem is really starting to sound like an 'iPhone 4 Antenna' style problem. If it is a problem with the design of the phone, I wonder when (if ever), Sony will acknowledge the fault. My bet is that it is a design flaw, Sony is already aware of it, no software update will resolve it and it will probably just haunt the model till it is replaced. I base this on the fact that their only response so far is to blame the users other wireless hardware and then just sit quietly and watch.
vikigsv
Here too experienced signal loss (disconnected) when covering the corners.
ZdendaF
Same situation on my phone. The phone is loosing the wifi signal - disconnect when I cover the corners. That's bad, really bad. I don't think it could be solved by firmware update.
Torin
I have the same issue.
2.4GHz Signal strength full right next to router but 5 meters away, through just 1 wall, weak signal strength, drop outs and fail to connect.
5Ghz 5 meters away no signal.
I have rebooted, restored, and updated both phone and router (TP Link - TL-WDR 4300) and no change. I have tried mutiple channels, no change.
Old HTC Legend + Samsung Galaxsy S2 + 2 laptops full strength in same possition.
I can not use my phone for what I need as it is faulty.
Can Sony solve the problem or should I return to the retailer for a refund?
Baptist999
Bought two Xperia SP's recently. One for my wife and other for me...
Both suffer from poor WIFI signal, mine more than hers...
If I had known about this problem would not have bought them....
