The background picture in front camera is curved. Is this normal?
first users are gettings their xz1 compact and camera distortion is also there.
Sony, please make the lens correction function. this camera is unusable
Sony did not announce that there is no fix, so kindly abide from giving false statements.
@aierI'd say yes, wide angle lens tend to curve lines that are near the edges of the field of view.
Sony told in the XZP Thread that there is nothing wrong with the camera lens and its on pair with other manufactures picture quality.
You dont have to be Einstein to understand that they dont see this as a bug and therefore has nothing to be fixed.
please dont give false hope for people in here because most of them are on the edge with sony pictures quality problem.
Thank you
@Quester wrote:Sony did not announce that there is no fix, so kindly abide from giving false statements.
Ic... Dissapointed
@aier that's simply how physics work when it comes to wide angle lens. for example: https://www.google.com/search?tbm=isch&q=wide+angle&tbs=imgo:1&gws_rd=cr&dcr=0&ei=sFjNWYn3NYeQ6QSYwp...
I dont think wide is better than straight image
Do not be fooled! Sony employees say it's normal, it's a lie.
