XZ Phone Super Heats and battery drains fast
Elang
As per instructions provided in the manual , i charged the phone for 30 mins before switching it on .  The phone got super heated and it radiated good heat energy, which clearly sensed in palms when we hold it.
Also when i was on call, my ears could sense the heat the device radiates.
Does any body faced the heating issue while charging and talking.
Thanks
A.Elang
23 REPLIES 23
tpwzrd
just thought i would reply on the disgrace to my phone overheating i sent it to fone biz at my cost which was disappointing only there have had it 2 weeks awaiting part under warranty only had the phone 4 weeks and it not going to be replaced good luck if you have a fault with your phone it should be replaced very annoyed so im going to get a brand new reapired phone again some time this year
iBoss
well, now i'm on the latest build number of android nougat 7.0.. the build number 39.2.A.0.417
and i have a unusual battery drain even when phone is in Idle... my Z5 Compact's battery won't drop that much in Idle compared to XZ... also when i'm using my XZ battery % drops very quicly!
well, I have smart cleaner activated, also the same for battery care!
is it the main cause of battery drain?
thanks
Tags (1)
Garethfinlay
Had mine about 2 months does not last a day and when using drops about 1% per minute seemed to happen after I activated lifelong and can't turn it off could be a coincidence
Sv22
I have the same problem and more.
My phone is little bit hot while is off. If I charge the battery at 100% and leave the phone turned off, after 6/10h I have phone totally discharged. And during this time I have my phone warm in the zone of CPU(on back near rear camera). It seems as a CPU works while phone is OFF. This isn't normal
