Wonder if anyone has found teh battery life to not be as good as expected? Anyone wish to share their battery graphs to show how good/bad it is?
Hi kwa1988
Can you please specify the Device you own with Android software Build no# ? "ex: 10.5.A.0.230"
most battery issues are resolved with system Updates but let us get details first on your device
BR
Koptan
I have a xperia Z I was asking more to see what usual use is like on the z3 to know if I want to upgrade to it or not
well i think it's too early to judge
because with my experience with Sony, they are used to push the hardware to it's limits in the first firmware release, then push an update later on to optimize the performance,
bottom line..
performance cannot be debated, you'll get the best.
battery life, you'll have to wait for a couple of months for that
BR
Koptan
You can test your phone with
https://play.google.com/store/apps/details?id=com.sonymobile.androidapp.functiontester
Ok, but that's normal
