battery issue
faisalalazzah
battery issue
I meet to know how to check if my battery is working fine any suggestion it from fully charges after 3hr and 25 minute 69% now it shows 2days and 19hr but that can't be right coz it drop fast
33 REPLIES 33
Uliwooly
Indeed, just keep in mind the siize of the screen, also that you are using data, or wifi, it will drain a lot faster.
faisalalazzah
faisalalazzah
How can I send a pic to u to show u my battery life usage ?
Uliwooly
you can upload it here but I won't be able to see it unless a moderator approves the picture, BUT you can take the screenshot >upload it to box/dropbox/etc and post the link here
Uliwooly
That's normal, the screen will drain the battery more than anything else, that's true on other brands. tap on Screen and check how many hours the screen was on. also tap on the graph and take another screenshot and post the links here
Uliwooly
Keep in mind that if you set stamina mode on, but you sync multiple apps/services that require to be online and you exclude them from stamina mode (white list) you are pretty much defeating the purpose of stamina mode.
faisalalazzah
I did not get ur last part we u mean
