I have the same device as you, haven't seen this problem. Can you try to perform a software repair using PC Companion?
One thing you can try: settings-apps-all-camera,force stop and clear data. Restart.
My M4 Aqua also does it....and if I keep the phone vertical and turn it to the left so that the rear camera lense faces me, the onscreen "soft"button goes off the screen with a beep....that beep is the camera trying to focus....
There is nothing wrong other than that....I see it as a problem with the camera software not being able to cope with the lense being to close as in a few inches to over twelve ...
A sensor probelem?
Regardless of resetting everything or even putting original software back, still does it.
