hey I notice some noise in sound background while playing music
using stock music player , stock earphone of Z5 , no contact with water at all
it sounds like "shshshshshshshs..." It is more noticed with higher sound levels
I think it is a software issue .. I hope it will be fixed sson
Model: E6653
Build Number: 32.0.A.6.200
the problem was fixed by turning off Dynamic normaliser :smileysmileywink:
