Headphone jack doesn't work?
velvetmxo
I tried plugging the headset that came with the phone and no sound. i tried the same headset on my spare phone and it works.
my firm ware is up to date Build 14.1.B.1.532
1 ACCEPTED SOLUTION
Uliwooly
My bad, I misread, how about if you update your phone
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
PC Companion (PCC)
Bridge (for Mac)
Don't forget to give Kudos (Click on the half star + )
17 REPLIES 17
Uliwooly
Were those headphones included with your phone? Do you have another pair of headphones?
Open all the flaps and check if there's either a white or pink or red rectangle (in each compartment)
velvetmxo
yes headphones were included and i tried 2 others that work. i got the phone monday.
also i don't see any red or pink color of those shapes. the only red i see is the reset/power button
velvetmxo
the two other headphones work, but not on the phone and no pink everything is white
Uliwooly
That's the problem, your phone has water damage, those are the water damage indicators, if the flaps aren't properly closed water will leak in.
You could take it to a Sony repair center and request a "vacuum test" to see if it was you who didn't closed the flaps properly or if there flaps are faulty.
velvetmxo
what are you talking about the phone has never been near or around water and there is no pink anywhere. pink indicates water damage, which is clearly not the case. i got the phone on monday
velvetmxo
again the only red/pink is the POWER button or reset whatever you want to call it
Uliwooly
PC Companion (PCC)
Bridge (for Mac)
velvetmxo
Well i am updated to14.1.B.1.532. Do i still need to do the method you mentioned?
Uliwooly
it doesn't hurt to repair/reinstall the software
