Headphone jack doesn't work?
velvetmxo
I tried plugging the headset that came with the phone and no sound. i tried the same headset on my spare phone and it works.
my firm ware is up to date Build 14.1.B.1.532
17 REPLIES 17
velvetmxo
Ok i will give it a go. After a full charge.
velvetmxo
thanks
Uliwooly
I'm assuming that it worked
velvetmxo
Yes it did thank you
Uliwooly
Anytime Slightly_smiling_Face
ankur1319
Hey if my phone has a water damage and my usb dock flap is faulty that is lose then will it be covered in warranty or I'll have to pay
ankur1319
And yes my earphones jack is not working too and there is something white near my sd card in the flap and which is completely white.and my proximity sensor is not working now what to do
shreyas4394
I am facing the same problem about headphones not detecting. I tried several factory resets but still the problem is not solved. I also tried a repair. Still same issue. Is it any thing wrong with the hardware or itz just a software issue (bug)
Please help!!!!
