Huge battery drain and a lot RAM consuming by com.sonymobile.intelligent.iengine app
Loki_
Hi guys,
After a long time ago i'm writing this. there is a lot of RAM consuming and battery usage by the app com.sonymobile.intelligent.iengine. i have attached a screenshots for your reference. and my question is how to avoid this and is there any problems to face or performance loses if i stop this app???
Finally for which function this app (com.sonymobile.intelligent.iengine) belongs to and what are the functions it supports?
1 ACCEPTED SOLUTION
hedrox87
Contributor
It might be a part of smart screen rotation app... phone detects with front cam in which position is your face and decides to turn the screen on the side as gyroscope is advicing. I'm not sure but I have all the intelligent stuff turned ON, just besides the smart rotation and I don't have this process showed in my phone, so I guess it's not any of smart backlight control or smart call pickup without sliding green bar. See If you have the smart rotation enabled in screen advanced settings.
2 days in my Z2 is normal.. If I didn't panic at 35% I could easyly go for 3 days and 4 hours without charge, but I talk a lot and I try to never go to work with phone under 60% charge.
8 REPLIES 8
profile.country.RO.title
_alexdon_
I suspect it might be related to smart call handling.
alexdon
Loki_
Hi Alexdon
Thanks for the response, i'll check once by disabling the smart call handling function. From the purchasing time i'm using this call handling function and i have not faced this issue but from past 4 to 5 days i'm getting lots of RAM usage. and i have deactivated smart backlight function also.
_alexdon_
Keep us updated.
alexdon
shruthi31
Hi guys i bought my xperia z2 oct 2 2014 in india..n my battery consumption of screen shows 68per. Is tgis normal??i read books on my phone
NirmalSitaldin9
Did u really get 2 days out of one charging cycle??
hedrox87
Contributor
NirmalSitaldin9
Ooh ok ok, mine goes 1 - 1.5 day with heavy usage, without 2 - 3 days yes, without charging at all
Loki_
Thank you hedrox87, As u suggest it seems to be an issue by smart screen rotating. Now I have disabled the Smart screen rotation n now I have not seen that intelligent.iengine stuff on my phone.
And I have another problem with battery drain, charging will be consume upto 60% by screen, standby n idle mode.
Is there any solution for avoid this???
