Power management gone after update
Jack0311
Since the update to my z5 premium the power management section has gone and I can no longer change my power settings.
2 REPLIES 2
profile.country.US.title
Qatrium
@Jack0311
Stamina mode has been removed, here's Sony's statement about it:
Battery STAMINA Mode has been replaced with Google’s Doze and App Standby?
Battery STAMINA Mode provides a smart solution for managing power consumption, as does the combination of Doze and App Standby - so you can still enjoy using your device for longer with optimised battery life.
Doze intelligently regulates power consumption when the device is in standby, when the screen is off. App Standby further improves battery life by reducing the activity and data access of apps running in the background.
Because of the similarities - and as Doze and App Standby are integrated directly into Android 6.0 - we decided to remove Battery STAMINA Mode in this particular upgrade to ensure users can enjoy the same experience, without compromising on memory or processing power.
Is this the end for Sony’s Battery STAMINA Mode?
We can’t comment on the future of Battery STAMINA Mode, but as we know battery life is one of the major user smartphone pain points, we continue to develop bleeding-edge power consumption and saving solutions
Christofer
Champion
Hi @Jack0311,
In addition to what Quester posted above you should now have a menu called Battery Usage instead of the one called Power Management.
