SSL certificate problem with default browser
tottinghill
I have some SSL certificate problem. My clients said ,when he access SSL page , browser show Security warning Popup.
device:xperia ZR
browser: android default browser
↓warning message↓
There area problems with the security certificate for this site.
↓View cert.↓
This certificate isn't from a trusted authority.
I know this warning means  the certificate is from untrusted authority. But I use trusted auhtority(from globalsign).
And other device is ok (Xperia TX  and many device!).
So I guess ,maybe root certificate with globalsign in xperia ZR isdisable or expiration of a term.But other website using same root certifacate is ok,
How/Can I solve the problem?
thanks
1 ACCEPTED SOLUTION
tottinghill
thanks for your help. Date & Time setting is okay.
but,this provlems is self-solved.
just adding cross root certificate to intermediate certificate authority.
3 REPLIES 3
Rickard
Master
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I recommend that you first ask him to check that the phone is set to the correct date under Settings -> Date & time.
If that's not the cause, could you give me the url where this is happening?
tottinghill
99992
Security certificate not much in Facebook
