Hi!
I bought Z2 a month back and have problem with its screen. There is a background lines and I tried to change the screen setting but no effect. The change of wallpaper was also of no use. I dont know how sony make such poor quality mobiles and when i check on the net I found many issues with sony Z2 mobile next time I will buy HTC never sony....
Hi, could you explain a bit further regards the lines......do you only see these lines at certain angles etc......could you take a screenshot & post it up here
Hi!
They are back ground lines or rather broad bands running top to bottom. Yes I installed 3rd party wall papers. But once i noticed this i even tried to uninstall them but the lines are there. Also inaddition to that there are shades around the symbols and icons what ever is changed the similar shades comes of that particular icon just like shadows. Any how the I have returned my mobile to the shop where I have bought this in with in warranty period so they will service my mobile.
Another friend of mine who bought Xperia Z around 2 years back got his mobile dead he has sent it to service but when i asked him he said they will try out but no hope.....
So how sony not address this issues paying so much....dead or issue like this....I have not heard any samsung being dead
Regards
Hi!
I installed wall papers...Does it affect like this....any how i uninstalled most of them.... still problem is there
Thanks
Hi!
I have given back my mobile to the emax showroom from where i bought it they will get it for me right. any how thanks for your suggestion i will do myself incase any thing in future.
Regards
Hi, that's good......keep us up to date with what happens & good luck :smileysmileywink:
