zl 10.3.1.A.2.67 problems
yatheesh
1. Overheating
2. Battery draining much faster than before
3. Call blocking option has been removed
4. Cant set lockscreen walpaper from album (can only set stock wallpapers)
Has any1 facin same problms r its only happen to me!!????
1 ACCEPTED SOLUTION
Rickard
Master
If you have a memorycard in the phone, try removing that and restart the phone. Also make sure that you test this with a picture taken with the phones camera. If that doesn't help i recommend that you try making a repair of the phones software using PC Companion: http://www.sonymobile.com/global-en/tools/pc-companion/
Start PC Companion without connecting the phone and go to Support zone -> Software update -> repair and follow the instructions but please note that this will reset your phone.
7 REPLIES 7
suyogpatil
refer this link :-
http://talk.sonymobile.com/t5/Xperia-Z-ZL-ZR/10-31-A-2-67-draining-battery/m-p/401237#M20096
and about  lockscreen wallpaper not sure but I am able to change it from album from setting option
Don't Forget to press Kudos If you find any post helpful.
Mark posts that answers the topic as Accepted Solution.
Rickard
Master
As suyogpatil says, when you go to Settings -> Display -> Lock screen the phone should ask you if you want "Album" or "Xperia wallpapers". If you don't get this option, see what app that opens when you select Settings -> Display -> Lock screen and then go to Settings -> Apps -> [that app] -> Clear defaults.
You can still block numbers from calling you. Add the number to a contact and then edit that contact. At the bottom you'll have an option to always direct that contact to voicemail. You can also download a call blocker app from Google Play.
yatheesh
None of the tricks r working..
I ve clear'd de cache and data of lockscreen app...
(I vent set any defaults..
It asks xperia wallpaper n album..
If i select any pic in album it shows croppin ..after clicking ok, it come back to setting menu and shows setting lockscreen walpaper failed)
Rickard
Master
Does this happen also when you select a picture you've taken using the phones camera?
What happens if you try this in safe mode (http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008)?
yatheesh
No changes in safemode..!!
Shows a msg "could not set wallpaper"
Rickard
Master
M_A
Hi
My Xperia ZL is not getting charge. I dont know what is the issue with it.
Please advise how can it be resolved.
