kdl 50w755c remote control problem
desmo999s
Had to change battery to remote control to an amplifier Nad d 3020 and this does not work after the remote control of my sony tv. Then I pulled out and I put the batteries of Sony remote control and afterward WORK.
Why?
2 ACCEPTED SOLUTIONS
desmo999s
THERE ARE NO oxidation. Television is new two months. If when power on tv press power on first from nad u3020 then the remote control of Sony do not work.as to block the FREQUENCIES.The same happens if you press first power on from sony Tv then should take out the batteries from Nad remote control.
Remote codes from Nad D3020.
Model D3020 Function Format Address Data Comment Hex Hex Dec Dec Address Data
Aux 1 NEC 877C 9B 34684 155
Aux 2 NEC 877C C0 34684 192
Bluetooth NEC 877C C2 34684 194
Coax 1 NEC 877C 85 34684 133
Computer NEC 877C 91 34684 145
Mute NEC 877C 94 34684 148
Optical 1 NEC 877C 89 34684 137
Optical 2 NEC 877C 8D 34684 141
Power Off NEC 877C C8 34684 200
Power On NEC 877C 25 34684 37
Source Down NEC 877C 1D 34684 29
Source Up NEC 877C 1A 34684 26
Volume Down NEC 877C 8C 34684 140
Volume Up NEC 877C 88 34684 136
November-18-13 IR Commands by Model Page 31 of 135
desmo999s
Thank you very much thou incredibly:smileythumbsup:
9 REPLIES 9
Not applicable
Hi there
Sorry, im a little confused at your description.  Maybe it was just coincidence that the Sony remote didnt work atterwards?
Caledonian_TV
Contributor
Why?
Most-likely oxidisation...   Remote controls draw very little current, and even a new battery can have just enough of a 'film' over the contacts to stop them working. - It's good practice when fitting batteries to give them a little 'spin' with your thumb to make sure both battery and contact are 'scraped' together and make good contact...
The action of removing and refitting a battery is sometimes enough to clean the contacts... Because contact and batter get scraped together in the process.
desmo999s
Caledonian_TV
Contributor
It would help if you were a little more coherent...  These remote controls work via infra-red light; not radio frequency transmission!  - So quite what you're referring to really isn't at all clear!   - Likewise, and I'm assuming here that English isn't your first language, BATTERIES are these things -  https://en.wikipedia.org/wiki/AA_battery
- Doesn't matter if the batteries are 'new, two minutes'!  - They can be oxidised enough to stop a remote, or any other low-current device from working until you 'wriggle' them a little onto the contacts.
Why are you removing them from the remote controls?
I'm GUESSING your post is really about your NAD amplifier's failure to 'learn' the remote control codes to operate your Sony TV?  - In which case you would be better looking for a NAD forum where people who own that equipment might be better-acquainted with the peculiarities of that particular amplifier.
desmo999s
I had LG TV with the same Nad and i had no problem.I put new batteries today morning and i had the same problem.The batteries have no problems.And repeat.I have all devices on a extension lead.The evening sleeping Ι press OFF button.The morning press ON button. If IMMEDIATELY AFTER press power on button of NAD remote control, the control of SONY TV not working.Must take off batteries of SONY remote control or make restart TV with use SONY game pad PS4.
Caledonian_TV
Contributor
Frankly Desmo, you are writing in riddles...
You didn't previously mention extension leads or a PS4; as to listing the remote codes for your amplifier - all of these thngs seem irrelevant anyway.
As far as I can gather, your NAD amplifier's remote is a  'learning' or universal type - it  simply learns the basic remote codes from your Sony remote. The only thing that occurs to me is that you may be trying to program it from a touchpad remote rather than the main remote - but I'm not even sure about that as I thought these were Bluetooth.
However...  You should program your NAD remote control from the TV's MAIN remote control... NOT the touchpad remote if you have one. - The reason for this is that the supplementary touchpad remotes are individually paired to the set; and the results of 'cloning' it are therefore unpredictable.
Other than that, may I respectfully suggest that you ask a friend with a better command of English to explain your problem. As I'm afraid what you have written so far really doesn't make very much sense.
desmo999s
[quote] However... You should program your NAD remote control from the TV's MAIN remote control... NOT the touchpad remote if you have one. - The reason for this is that the supplementary touchpad remotes are individually paired to the set; and the results of 'cloning' it are therefore unpredictable. [/quote]
How can I program my NAD remote control from my TV's MAIN remote control?Can you link me to a guide or something familiar? Also I don't have a a touchpad remote control. Thanks in advance.
Caledonian_TV
Contributor
See page 9 of the NAD's instruction book for details...
desmo999s
