WiFi Hotspot not working after JB update :(
ixis24
So, as the title says, the WiFi Hotspot feature isnt working after the Jelly Bean update Crying_Face I have rebooted the phone several times, including cold reboot, holding down power & volume up, but its still not working. I have also tried using a different network names and passwords, but still nothing. I was perfectly able to use the hotspot feature before the JB update, used it everday to connect to my tablet.
All other features work so far on my phone, tho i havent tried the walkman app.
Please fix....please :smileygrin:
42 REPLIES 42
bloxx
bloxx
how to root wiil show you how to push kernel or img file to you phone just type in the  instructions in the list or just do  anew install with these instructions ok
Guillaume17
Here is the name of the last ICS Official Firmware for XPeria T:
LT30p_7.0.A.3.223_1265-1626.ftf, avaliable here:
https://docs.google.com/file/d/0B2OI_oeXmtLFLS01YTBnWVFJRnc/edit?pli=1
(You need to be connected with your Gmail account)
The 9.1.A.0.489 is Jelly Bean
bomber_f
It's international version? Is Italian language inside?
Guillaume17
It's a Europe version. I've installed it in french and I saw many languages after restart, Italian was in the list for sure.
Johan
Master
I checked but I wasn't able to replicate this problem using JB in a Xperia T. But I know that this discussion has been up before for other models and versions of Android. Could you please verify with your network operator that you have the required subscription to tether mobile data?
bomber_f
I checked inserting the simcard in my old sgs+ and it works normally.
Today I went to a sonyericsson support center, they told me they sent another xperia T to fix the same issue and it takes at least 10 days for that... Slightly_frowning_Face
bomber_f
Ok, here's the solution: new update .492 solves that issue.
http://forum.xda-developers.com/showthread.php?t=2179641
Thanks Sony, it took a month but that issue was solved.
