Alarm issue
Jlu2
Alarm issue
There is one time alarm  When new message  came. There's no more reminding even the message wasn't checked. Is there a way to set the alarm keep running, say every minute until the message is reviewed? Thanks!
1 ACCEPTED SOLUTION
Uliwooly
@Jlu2
Nope, you will get whichever notification (sound) you've selected; the LED notification should keep blinking unless you've disabled this option; with that said, you can use a third party notification app
4 REPLIES 4
Uliwooly
@Jlu2
Jlu2
thank you for such a quick
Uliwooly
@Jlu2
Anytime
Jlu2
Thank you for such a quick response! The light does keep blinking.  I will see if additional app could add sound or vibration.
