Finger print entry has stopped working
Shabz0
Since I bought the phone in march 2017, vodaphone staff set up my finger print entry. Now March 2018, device  has stopped and does not recognise my thumb.
Could anyone advise please  the steps on how to get it started again.
Speak soon
Shabbir
1 ACCEPTED SOLUTION
Jonas
Master
Hi @Shabz0, sorry to hear about this. Slightly_frowning_Face
Is it only the thumb that it doesn't recognize? You can add up to 5 different fingerprints and use all of them to unlock your device, so if you haven't tried removing the old one / adding a few more, I'd recommend doing so, in Settings > Lock screen & security > Fingerprint Manager.
As @uliwooly mentioned, make sure that both the finger and the fingerprint sensor is not dirty or wet, which will make it harder for the device to recognize your fingerprint.
Let us know how it goes! Slightly_smiling_Face
24 REPLIES 24
Uliwooly
@Shabz0
Settings > lockscreen & security > Fingerprint Manager
Make sure to clean the fingerprint reader.
Jonas
Master
ShoganCO
I have owned this phone for a couple of months now and the finger print reader has functioned flawlessly. THis morning the Xperia software crashed, caused a reset of my phone and now the reader is not functioning. It continualy states "Move your finger a little bit" after the first couple successful reads and then times out. I ahve tried all fingers, all generate the same response. Any ideas?
Jonas
Master
Hi @ShoganCO, sorry to hear about this. Slightly_frowning_Face
Just to make sure that this is not caused by the software in device as it occurred after a reset, try performing a software repair using Xperia Companion. This will remove all data stored on the internal storage of the device and reinstall the latest available software version. Since data is being deleted, it's important that you create a backup using Xperia Companion before you start with the repair process!
Let me know if that helps!
Shabz0
Jonas. Hi.
My finger print entry is working fine now after I used the basic settings to reset it. Clean and dry.
Thanks again for looking out for me.
Speak soon
Shabbir
Richarddd
After a long time of working without any probleem. My fingerprints Just stopped working.
I'll try the soft repair wich is adviced. Allthough the advice comes from the forum, and not from Sony itself, it sounds reliable 😉
Jonas
Master
Hi @Shabz0, you're very welcome and I'm glad to hear that it's working now again! Slightly_smiling_Face
Let me know if there is anything else I may assist you with and have a great weekend!
@Richarddd, keep us posted on how it went, and I'm a Staff member so you can trust the troubleshooting that I recommend! Slightly_smiling_Face
Keep me posted on how it works after the software repair!
Richarddd
After checking out the software tool, I decided to do nothing for now.
And two days later, the fingerprint worked again.
It seems like 'waiting' solved the problem 🙂
Jonas
Master
@Richarddd, Hello again! Slightly_smiling_Face
I have been out of office due to vacation so sorry for my late reply, but I can see that I'm back to some great news and I hope that the Finger print is still working for you! Slightly_smiling_Face
Have an awesome morning/day/evening!
