wifi and bluetooth issue
EdwardH2
So this has been annoying me for months, My wifi always drops as soon as I connect to a bluetooth device. It's not just my Z3, but my dads does the same thing and a lot of the time our phones seem to interfere with eachother in the same way. Not sure if it's a problem with the router? Or if it's a device problem. But either way, it shouldn't happen. It was fine until the latest update
1 ACCEPTED SOLUTION
Lord_viridis
Ahh ok, then the problem is the 2.4ghz frequency that your router and Bluetooth are both using.
The fix is to use a 5ghz connection so it won't get interference with the Bluetooth of the dualshock 4.
Annoying and will cost, but that is the fix.
13 REPLIES 13
Curnow1
Contributor
Settings > apps > all > smart connect > clear data > restart device
Uliwooly
Do you experience the same on Safe Mode?
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
if you don't then its a third party app acting up.
EdwardH2
That hasn't worked... I haven't tried safe mode, the only reason it's pissing me off is because I bought a PS4 last night and i can't do the remote playe because it just cuts off my wifi every time i try use bluetooth at the same time
Uliwooly
repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
EdwardH2
I already repaired my phone after i installed the update before christmas
Uliwooly
Just give it a shot and try again.
EdwardH2
Way too much hassle having to back up and restore along with reinstalling apps because the back up doesn't do that for you. I'll wait for lollipop and see if that makes a difference
Uliwooly
I understand but if its going to solve the issue, then its worth it
EdwardH2
the problem is, it may not fix it? And then it's just a big waste of time. I noticed that after like 20minutes of leaving them both on they seemed to work fine which is strange
