WiFi Hotspot not working after JB update :(
ixis24
So, as the title says, the WiFi Hotspot feature isnt working after the Jelly Bean update Crying_Face I have rebooted the phone several times, including cold reboot, holding down power & volume up, but its still not working. I have also tried using a different network names and passwords, but still nothing. I was perfectly able to use the hotspot feature before the JB update, used it everday to connect to my tablet.
All other features work so far on my phone, tho i havent tried the walkman app.
Please fix....please :smileygrin:
42 REPLIES 42
siva_patel
OK, I've fixed it!
Used FlashTool64 and the firmware download from here. It's version 9.1.A.1.140 and tethering now works.
ixis24
IVE FIXED MY TETHERING!! Nauseated_Face
i was trying to add a new APN but it wouldnt save, i then acccidentally deleted the apn settings! but on adding a new one, my tethering now works!! Nauseated_Face
click here to get the APN settings for your network...  http://www.geeksquad.co.uk/articles/series/apn-mobile-network-settings-learning-series
Follow the instructions, then hopefully it will work for you too :smileysmileythumbsup:
Sooo happy to have tethering back! One thing tho, there has to be right! I accidentally deleted the mms settings, so i probably cant receive picture texts, well, i say that, i havent tried yet, no bother tho.
Happy tethering people Nauseated_Face
Gamma2391
I've got the same problem. I have heard that Android 4.4.3. fixes the issue!
In between are there any fixes with the settings of the phone? I don't really want to root the phone as it revokes the warranty.
Keep positive!
