Xperia SP WIFI range ISSUE
ak_newlife
Hi, i have just bought Sp 2 days back
I am facing wifi range problem the device does not catch the range where my other phone catches the range at good wifi signal strength.
the distance is like 3 to 5 meters less then my black berry
Is there any settings that i need to see for the wifi range.
205 REPLIES 205
bonib4u
I have also the same problem... (Xperia SP)
max 4 meters range  available... my laptop is working fine even at 10 meters from the router..
My wifi operating @ 2.4 GHz. Is there any option in mobile fone to select the operating frequecy like 2.4 or 5 Ghz!!
post some permanent solution
Johan
Master
Could you please send me your details in a PM, and I will forward this.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Product(s):
IMEI nr:
Build number:
axljackass
Hi Johan, kindly check you email.
Finally Sony saw this issue,
Will post here for any update.
davidorabig
Issue is definately with the phones, all other wifi devices i use have between 5 - 10 metre extra range, this is one tablet, 5 phones, 3 computers, the SP can't even get close to the other devices, shortest range of any device i have used, I've got 5 days to return, perhaps will have to switch samsung or HTC, trouble is i actually like the SP, please let it be a sony software issue, and please update soon.
piefert
I have mailed Sony and got a response with the advice to repair the Xperia's software using PC Companion. I did exactly this and had no results. I still have problems with range and sudden loss of connection. Although i'm pretty sure the suddden loss of connection is a software problem, i am not so sure about the range...
valkyrie1
Sony Xperia Contact Centre replied by asking me to get in touch with my network service provider to change my wifi signal from 1 to 11. Has anyone of you tried that? Anyway, I sent them a photograph of my two Xperia SP side by side showing the big difference in the number of wifi network detected, which translated to a much shorter range for one of them.
Torin
What does that even mean? your router sets the channel number not the service provider? That sounds like a typical call center "go away and stop bothering us" advice.
With my router it is set to variable. I have also been through every available channel and setting on my router with no change.
I am getting the feeling that this is a terminal component problem that effects only a few SP devices and the only solution is a replacement device from a different batch.
axljackass
Not only with Xperia SP but also with other model like Xperia S, tested and confirmed!
If Sony wants a proof kindly PM me and i'll happy to demo in front of you!
ak_newlife
I think the "This question is Assumed Answered." needs to go aways. and un resolved or pending needs to come in.
k_nice
Same problem here. My old HTC Wildfire and my Macbook have full range, my SP keeps switching between dataconnection and wifi. Definitely PENDING imo.
